Adjustable Pushrod.
Old Oct 17, 2019 | 02:47 AM
Bill Chase's Avatar
Adjustable Pushrod.
I have a 383 crate shortblock that has been decked and squared up. With afr 195 street eliminator heads. Based on part numbers used it's safe to say the block has had about. 020 removed from the original deck height. An erson hydraulic roller cam and Elgin 1.6 steel roller rockers.
Obviously I will have to check pushrod length. My question is with so many length ranges available for adjustable pushrod which do I get? From 6.5 to 7.5" ? I am hoping I do not have to buy multiple checkers. I would rather spend 20 dollars vs 80 for a complete set.
Old Oct 17, 2019 | 07:35 AM
Re: Adjustable Pushrod.
This is the one I have. https://www.summitracing.com/parts/cca-7702-1/overview/ Covers the range you need.
Old Oct 18, 2019 | 02:49 AM
Bill Chase's Avatar
Almost ordered the wrong one. Failed to consider factory roller cam setups are quite a bit shorter than standard flat tappet setups.
eduardosac
Dec 27, 2015 12:24 AM
91chevz71
Nov 12, 2007 08:42 PM
88_Import_Slaye
May 28, 2004 12:38 AM
79_EFI_Z
Jan 29, 2004 02:12 PM
kidcamarosc
May 30, 2003 07:18 AM
