Easiest electric fuel pump conversion?
Car: 1985 Trans Am
I've got an '85 that originally came with an LG4 so as far as I know, it has no electric fuel pump. I've just picked up an L31 to build and swap in so I'll need to convert to an electric pump. What's the easiest way to do this on our cars that don't have fuel pumps in the tank?
Re: Easiest electric fuel pump conversion?
Should have a lift pump in the tank. For replacing the engine mounted pump, I've had good luck with these little guys:
https://www.holley.com/products/fuel...s/parts/12-428
GD
GD
I used this one. But mounted close to the tank to give the fuel a push up to the block-mounted mechanical FP.
mw66nova
Carburetors
11-13-2003 11:31 AM
