Air bleeding Oil pressure gauge? False reading?
Old Nov 28, 2019 | 03:30 PM
maroe624's Avatar
Car: 92 Z28 Clone
Engine: Vortec 350
Axle/Gears: 3.23 Torsen
Made the switch to synthetic and I noticed the line running to my oil pressure gauge has many sediments of oil, from really dirty/dark oil to cleaner/lighter oil and in between. When I rev it up I can see the sediments bunch up and was wondering if that could throw off the reading. Probably doesn't make a difference since its just pressure right? Might try bleeding line just to see if it makes a difference.
Old Nov 28, 2019 | 03:49 PM
GeneralDisorder's Avatar
Re: Air bleeding Oil pressure gauge? False reading?
It doesn't matter.
Old Nov 28, 2019 | 07:06 PM
OrangeBird's Avatar
Car: 1989 Firebird
The fact that you can see anything in the tubing connecting to your oil pressure gauge means that you've got the wrong tubing hooking it up ......
Yeah yeah , , , I know , they sell the plastic garbage with the gauge , but it's the worst stuff to use because it will , no , not it may , but WILL , eventually harden , become brittle , and break , soaking your carpet with oil .
The right stuff to use is copper tubing , it comes in the same size as the plastic crap , fits the same compression fittings , and at least at my local autoparts store is sold on the same rack with the gauges .......
Old Nov 28, 2019 | 08:15 PM
When you redo it with copper, make sure you leave several coils at the fixed ends like the gauge and the engine for stress relief. If you don't the copper will work harden and break off at the fittings. Also be VERY careful tightening the ferrules as it doesn't take much to damage the tubing.
GD
Old Dec 4, 2019 | 12:46 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
GD
What he said. I wrap it around a 1 1/4 impact socket to make even coils so it looks nice and neat.
shrewdpeach1609
Jul 23, 2016 06:01 PM
x91xCamarox
May 13, 2011 08:18 PM
R4][N_M4l{3R
Jun 7, 2007 03:48 PM
85SportCoupeto89RS
Apr 20, 2002 09:23 AM
GCSIROC
Mar 18, 2002 02:06 AM
