What Oil pressure gauge do our v6's use
Old Apr 17, 2002 | 11:22 AM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
Is it the 80psi or the 60? I remember somebody posting this a while back but the search turned up nothing.
Old Apr 17, 2002 | 12:14 PM
Kevin S's Avatar
My 89RS has a 80psi guage.Hope this is what your after.
Old Apr 17, 2002 | 07:43 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
To the extent of my knowledge, only the V8's use the 0-60 PSI oil gauge. All the 6'ers use the 0-80 PSI gauge.
Old Apr 17, 2002 | 10:29 PM
Car: 85 Camaro SC
Engine: V6
thanks
Old Apr 17, 2002 | 10:39 PM
KED85's Avatar
After the engine has been shut off, what does the gauge pressure read?
What does the pressure read for idle, after warmed up?
Old Apr 17, 2002 | 10:48 PM
Car: 85 Camaro SC
Engine: V6
I have no idea Karl, I need to put the 80 psi gauge in.
Old Apr 19, 2002 | 11:24 PM
Car: 85 Camaro SC
Engine: V6
I finally got to drive my SC down the road :hail: the gauge reads at 40 psi during idle.
Old Apr 20, 2002 | 09:23 AM
KED85's Avatar
When I swapped the V-6 oil pressure guage, onto my V-8 dash set up, I'm afraid my needle may be not adjusted correct.
I didn't want to take a chance of the V-8 dash gauge not reading correctly the 80 lb pressure unit readings.
Attack from above or below, sender replacement.
I know use big & small wrench.
89GTAOz
May 16, 2020 09:31 AM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
ChevyZ71
Aug 13, 2015 07:30 AM
