Distributor swapping??
Old Jan 12, 2002 | 08:42 PM
383toy's Avatar
I have a 1990 TPI intake with a small cap distributor and external coil. I wish to replace my small cap distributor, with the large cap out of a 1986.
Can I do this??
I already know about the wiring differences and that is pretty easy to get around. My concern is the distributor shaft size and the output of the coil itself. Corvette used a large cap distributor throughout 86 - 91, but I noted from GM that the part numbers are different than the 86 Camaro distributor.
My goal is to use an internal HEI MSD coil that I have kicking around and to clean up the engine compartment a bit.
thanks for the help
Old Jan 13, 2002 | 12:45 AM
wuter's Avatar
its a direct bolt in except for the connectors being different, also make sure you swap the gear for a bronze one if you have a roller motor.
Old Jan 13, 2002 | 02:10 AM
383toy's Avatar
thanks for the info.
Any idea why the Corvette would have a different part number?? they used the large cap HEI from 85 to 91.
Old Jan 13, 2002 | 12:36 PM
wuter's Avatar
i am guessing the different part numbers are because the only fbodys to get this distributer were flat tappet cam (85-86),, and corvettes used roller cams, (87-91), with it so the gears are different.
midge54
Jan 29, 2017 07:00 PM
LittleFranks
Sep 17, 2015 12:22 PM
355sbcTPI
Aug 19, 2015 04:38 PM
86IROC112
Aug 17, 2015 07:57 PM
cstrobel65
Aug 15, 2015 10:19 AM
