Starting problem
Old Jan 16, 2020 | 05:50 AM
Luvmusclecars's Avatar
Starting problem
I’ve replaced starter, and now periodically when u turn the key it just clicks sometimes just once sometimes 4 times in a row before it will start. Question is could it be the ignition switch? It’s a 92 Camaro with air bag
Old Jan 16, 2020 | 06:22 AM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
Re: Starting problem
.....could it be the ignition switch?
Yes. It could also be the starter solenoid, a loose/corroded battery cable, a poor ground, a bad wire or connection between the ignition switch and starter, or even a defective starter.
Old Jan 16, 2020 | 06:29 AM
thanks I will check those, I guess had the starter replaced yesterday so that is what made me believe it may be the switch but will definitely check the others
Old Jan 16, 2020 | 11:56 AM
erik69&85's Avatar
is it a remanufactured starter?
I have had the same problem in my 92Z... replaced the starter and it went away... but now i have had it happen a couple times in the new one ( few years later)....it seems to be the starter solenoid is not connecting the motor contacts... not sure why.. such a pain to get those in and out....
Old Jan 16, 2020 | 01:12 PM
HawkZ28's Avatar
Car: 86 Z28
Engine: Built 312
Axle/Gears: 10 bolt 3.42
I had a similar problem off an on with my 86.
1st time was loose ground at the battery.
2nd time was loose power- at the battery again.
3rd time was my neutral safety switch bypass- I rewired and it has performed flawlessly since. Knock on wood.
Old Dec 26, 2020 | 04:33 PM
Moonlight137's Avatar
Car: 1992 RS
Engine: L03 / MSD / 2½" "hacksaw" catback
Transmission: 4L60
Hi, I hope everyone had a merry Christmas! Reviving last January's thread just to chip in my
I had exactly the same intermittent starter "click" problem, I tried this and that, checked all my flywheel teeth, removed my battery cables and cleaned everything I could reach, etc, but no luck.
Then I removed the battery again, just so I could clean under it, and ever since I put it back together I've had no more trouble with my starter.
The basic issue may be that I have an old corroded battery terminal, but I haven't replaced it yet, and I haven't messed with it any more since it started working.
jaysfs
May 19, 2011 08:15 PM
srosscamaro@aol
Dec 30, 2009 09:24 PM
Lzybum06
Oct 27, 2003 02:20 PM
PimpRod92RS
Nov 18, 2002 08:41 PM
