113 head question
Old Jan 19, 2020 | 10:28 AM
my hemi's Avatar
Car: A few things lol
Engine: 350 tpi supercharged and a 383 stro
Transmission: Both 700r4s
Axle/Gears: 3.23s and 3.54s
113 head question
What is a good flowing 113 head flow once ported and polished I have a set just wondering if there flow enough.
Old Jan 19, 2020 | 11:03 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: 113 head question
It depends, are you going to do the bigger valve upgrade too? CNC ported with bigger valves seem to do the best but the down side is the cost to do all that.
Unless you are going for a "stock" look, I'd bump to an aftermarket head.
Old Jan 19, 2020 | 11:07 AM
my hemi's Avatar
I have a set that was done by tpis years ago wondering if it a good flowing head for what it is..
Old Jan 19, 2020 | 11:17 AM
TTOP350's Avatar
Yup, someone posted tpis flow sheet some place and they are good for the head. cnc ones I've seen are a tad better but probably not worth losing sleep over the difference unless you are going for max power.
Old Jan 19, 2020 | 11:31 AM
my hemi's Avatar
That was probably me..lol
Old Jan 19, 2020 | 11:33 AM
TTOP350's Avatar
It may have been lol What are the goals for the engine/car?
Old Jan 19, 2020 | 11:39 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Yeah 250 cfm is doing pretty good. They get thin.
Old Jan 19, 2020 | 11:53 AM
my hemi's Avatar
there on a 383,lpe219 cam, 1.6 rockers,first performance intake, 76 mm TB, edelbrock headers for now I have a set of slp 1-3/4 headers custom y pipe into a 4.5 mufflex exhaust 2600 stall convertor, worked 700r4,all being tuned by a holley hp efi system looking for mid 12s
Old Jan 19, 2020 | 07:09 PM
BadSS's Avatar
I'm pretty sure I have the flow numbers for the Weld/Hutter CNC heads somewhere around here but can't seem to locate them. Best I remember their numbers were about what you posted (maybe a little less). I did find the LPE flow numbers for their L98 CNC porting with 2.00/1.56 valves. Pretty sure their numbers were as high as I had seen published. So, you're heads should make plenty of power.
.200 140 116
.300 198 157
.400 242 185
.450 249 195
.500 254 199
.550 260 203
.600 263 206
Old Jan 19, 2020 | 07:20 PM
my hemi's Avatar
.200 140 116
.300 198 157
.400 242 185
.450 249 195
.500 254 199
.550 260 203
.600 263 206
Wow thank you for that info..I know you have built some nice builds were trying an old school build with new holley hp efi system installed looking to make some decent hp I think were on the right track..I have our TB with Ken now I'm having him take the 73 mm TB and making him open it up to a 76 mm TB the shop during our install wants it opened up no idea why but I trust him..hoping this car goes mid 12s..
Old Jan 19, 2020 | 07:50 PM
BadSS's Avatar
No problem. He opened one up for me as well. Should bump flow up to around 1,000 cfm and be worth a few HP. I ran 12.6s with a 10:1 355 with a box stock FIRST and throttle body in the heat with 240-ish cfm heads and a flat tappet hydraulic 218/228-110 cam. TH350 and 3.23s with 10" Street Fighter. You'll have more cubes, better heads and cam, with more gearing - so I'd say mid 12s shouldn't be a problem - assuming traction.
Old Jan 19, 2020 | 08:15 PM
my hemi's Avatar
Cool..I was afraid of opening up the TB I thought it would hurt performance heard it might cause tip on problems like bogging..but also heard with the Holley efi should correct that issue..I cant wait to hear this run.. also do you know if the lpe219 cam has a nice sound to it?
Old Jan 19, 2020 | 08:39 PM
BadSS's Avatar
I've heard of people having tip in problems but I've never had a problem getting enough fuel added to cover it. The only time I've heard the LPE219 was back in the early 90s. A guy bought a Vette with the 440HP 383 LPE engine with a SuperRam running that cam. Pretty sure it was idling rather smoothly around 750, which is what he wanted. I love sleepers so I like it as well. I had built a daily driver carbed 406 that was running 12.40s in a buddy's car. The Vette would jump out on him and he would reel him in right at the quarter-mile mark. However, I feel rather confident that the Vette was running a very conservative tune and had more in it.
Old Jan 19, 2020 | 08:46 PM
my hemi's Avatar
I know he said he was going to use 36 or 30 lb injectors we have a walbro 255 lph fuel pump .. fast fuel pressure regulator.. it's going to be a map car and like i said a holley hp efi system that should help in tuning.. we do have a mufflex exhaust custom made 4.5 in 2 chamber flowmaster the car should sound good..I hope..lol
Old May 15, 2020 | 09:06 PM
my hemi's Avatar
Well since this post we almost got done the 9 bolt started clunking so were upgrading to a S60 dana 12 bolt with 3.54 gears hope that will take the abuse...
firebird45331
Dec 5, 2005 03:35 AM
pasky
Feb 21, 2005 09:40 PM
