Damper belt pulley question
Old Mar 18, 2020 | 07:10 PM
Ct1987's Avatar
1987 Formula, 305 engine. I plan on changing my damper belt pulley to a serpentine pulley. My question is, which way does the damper bolt loosen. Clockwise or counterclockwise.
Thanks,
Louis
Old Mar 18, 2020 | 07:38 PM
Re: Damper belt pulley question
AFAIK all the bolts on our engines are CW tighten, CCW loosen.
The damper bolt is kinda tight. 60 - 65 ft-lbs when installed, prolly ALOT more to break loose. Fortunately though once broken loose it come out with fingers. I'd suggest locking the crank in place somehow, and using the longest breaker bar & impact socket combo you can come up with, to break it loose. An object wedged in the flex plate or some such works wonders.
Old Mar 19, 2020 | 09:12 AM
Ct1987's Avatar
Hi Sofa, thanks for taking the time to reply.
Louis
AC
Fabrication
Nov 29, 2009 02:22 PM
RiggsLW81
Apr 20, 2008 11:42 AM
DustyJL
May 31, 2006 09:07 PM
ColdGTA
Aug 4, 2005 09:14 PM
cort351w
May 16, 2002 01:07 PM
