Hello,
I posted this on Corvetteforums, but didn't get any replies... I need to replace the pump on my 4L60E trans (removed from a '95 Vette) and need to know if 298 or 300mm and also if Pulse Width Modulated (PWM) or Non-PWM? It's currently installed in a '76 Vette w/ the LT1 engine.
Is there any way to be certain w/o removing it first? Reliable sources informed me that it is MORE-THAN-LIKELY a 298mm, but '95 was a "transition year" for the PWM / non-PWM versions and could only be determined when removed. Are there any markings on the trans or ser#'s I can look for? I also have the VIN of the donor car... would that indicate anything?
Just trying not to use the shop bay it would need to be in for too long.
Thanks so much for any info!
Donovan
Donovan
