Need info on trans pump
Old May 22, 2005 | 06:15 PM
c0y0te56's Avatar
Car: 1986 IROC Z TPI Convert
Transmission: auto 4 speed
Well I goofed up Putting trans back in the car I didn't get the torqe converter in all the way and broke the pump. Bummer ruined the day
Anyway the question is,I know I need a tool to pull the front of the trans out , I'll make the tool, have to pull the pan and remove the filter. Is tere anything else to know so as not to break anything else? I've seen the pump rebolt so I have a good idea on that prossess.
Thank you in advance for the help JT
Old May 22, 2005 | 08:32 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Need to remove the torque converter solenoid too. You can pry the pump out from the back side, don't need any special tools. Has an o-ring seal, a gasket on the back, and small o-rings on each bolt. With pump out, careful not to pull on shaft in tranny, leave it fully in place.
AaronIROCZ's Avatar
Moderator/TGO Supporter
Make sure you pull the tcc lockup solnoid out, I didn't the first time I rebuilt my trans and I ended up breaking it.
Well I can see that tom beat me to it
Old May 22, 2005 | 09:12 PM
c0y0te56's Avatar
Thank you guy's you probably just saved me another bad day Thanks Again
Old May 25, 2005 | 09:18 PM
c0y0te56's Avatar
Well now there is no 4th gear
I installed a new pump housing and all. Now when I put car in 4th it tries to engage but acts like there isn't enough presure to get it goin. When in 3rd it shifts correctly up and down as its suppose to according to the rpm and throttle placement Any suggestions I am hoping for an easy solution. Thanks for any input
eightsixseven
Dec 16, 2024 01:50 PM
9192camaro
16
Feb 3, 2019 12:21 AM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
beachrodder
Aug 25, 2015 08:05 AM
gta power
Aug 13, 2015 06:15 AM
