Mechanical fuel pump failure
Old May 26, 2020 | 08:53 PM
Thirdmaro's Avatar
I cant find a definite answer for this but is there any chance that a mechanical fuel pump could fail only when it gets warm? As in when the motor reaches operating temp.
Old May 27, 2020 | 07:36 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: Mechanical fuel pump failure
System in general: the carb system's fuel lines run fairly close to the passenger side exhaust and heat can cause vapor lock, or more likely, hot fuel boiling in the carb.
ensure the return line is functioning properly and routing fuel back to the tank. you can check fuel return from the pump by removing the rubber return line and observing flow. you can also blow compressed air through the steel line back to the tank to ensure it is free of obstruction.
if the return system is not working, you will have hot fuel problems. even with it functioning you 'may' have hot fuel problems. later carb systems used an in-tank helper pump to combat this. it was also a retrofit option for GM service back in the day.
fuel pump specific: I've had a fuel pump fail so that it was not pumping efficiently enough to provide full flow and starved the car when hot. upon removal and inspection, the swaged fittings that hold the fuel pump's fulcrum had failed on one side. as a result the pump's 'lever' was not seated enough to provide full movement with the cam eccentric. it would 'pump' but probably not enough to flow adequate return to offset the heat. if that makes sense.
Thirdmaro
May 26, 2020 08:52 PM
AshlandTE87
Mar 24, 2020 06:27 PM
91GTABird
Dec 19, 2019 06:23 PM
-LateNite89-
May 13, 2013 09:53 PM
