Kemso 340lph fuel pump
Old Mar 21, 2020 | 09:05 AM
AshlandTE87's Avatar
Anyone here using the Kemso 340lph fuel pump? If so, happy with it? I知 on a budget build and there are a lot of fans of this $30 pump. TIA
Old Mar 21, 2020 | 09:16 AM
Lonnie P's Avatar
Car: 91 Formula
Engine: 2012 LS9
Transmission: 4L80E
Axle/Gears: Strange 60 3.54:1
Re: Kemso 340lph fuel pump
For the amount of effort it takes to change a pump, why buy something that invites doing it twice. Get a good Walbro pump & minimize your chances of grief.
Secondly the wiring bulkhead in the tank is not rated for the current draw of a 340lph pump. I have seen many of these overheat & melt.
Finally, unless you are making over 550rwhp, then you do not need anything larger than a 255lph pump. Larger is not better in this case.
Old Mar 24, 2020 | 06:27 PM
Thanks for the insight, especially on the bulkhead wiring! Yeah, I知 planning to be right around the range to where I値l need more than 255lph.
91GTABird
Dec 19, 2019 06:23 PM
-LateNite89-
May 13, 2013 09:53 PM
cam92rs
Aug 22, 2006 11:46 PM
Lee7
Aug 20, 2003 06:41 PM
