PCV routing with boost
Old Jun 6, 2020 | 11:56 AM
nebulous's Avatar
Car: 91-Trans Am-WS6
Engine: L05 350 - ATI 9psi
Transmission: Pro-Built:Street/Strip
I'm just now bringing this car back to life after many years of sitting in the garage, and the PCV system was setup in the stock configuration which is definitely wrong for boost. I'm running a P1SC (speed density/no MAF). Here's a diagram of what I've done. Is this routing insane? I definitely get more crankcase smoke/vapor from the breather under boost than I'd like. Years ago, my old Paxton setup had tubes for crankcase vapors to be fed back into the vacuum side of the supercharger, but I'd really rather not do that with my Procharger since oil would get all over the inside of the intercooler(not to mention general crud getting all over the impeller). It may be wildly unrelated but other variables I'm tracking are: making almost no boost (~3lbs) and lower than expected oil pressure(~30lbs).
catch can / check valves for PCV / boost
passenger side catch can
driver side PCV with additional inline check valve
Old Jun 6, 2020 | 02:28 PM
GeneralDisorder's Avatar
Re: PCV routing with boost
Do you even need a catch can? Unless the rings are spanked, or you are running high boost pressure (30+ psi), we generally don't recommend them at all.
Under boost the PCV valve is forced closed and crankcase pressure is vented through the filtered valve cover..... so are you thinking you are going to have a bunch of oil from the passenger valve cover under boost?
30 psi oil pressure under what conditions? Hot idle? In that case it's fine.
GD
Old Jun 6, 2020 | 04:26 PM
nebulous's Avatar
I at least needed a vent, and liked the idea of a catch can since it allowed me to move the blowby smoke/oil vapor a bit further away from the valve covers and headers. Oil pressure is actually worse than I said... more like 15psi all the time. Searches indicate this may indicate a sending unit failure. The engine has less than 5k miles on it since new, but that includes a long time sitting. I think the rings should be fine, but I've been wrong so many times before that I figured I'd disclose in case someone knew better. The main thing I wanted to know is if the check valves I added made sense in location and in gas direction. I'm not sure it makes any sense to keep the throttle body to catch can connection on at all for instance.
Old Jun 6, 2020 | 09:58 PM
No reason I can think of to suck anything from the catch can into the throttle body. I would definitely delete that and put another filter on that port.
Check the oil pressure with a mechanical gauge.
GD
Old Jun 8, 2020 | 09:43 AM
nebulous's Avatar
The rationale for the catch can-to-throttle body connection was that it would put vacuum on the breather more quickly, hopefully reducing smoke(which is substantial imo. dirties the windshield over time and just looks janky). Probably a paranoid choice on my part, and I do like the idea of two breathers on the catch can to possibly increase flow when under boost. I wouldn't be at all surprised if it were also the source of a giant boost leak(expecting ~7lbs, getting 3 - but it is _not_ tuned well yet) considering the hacky way I ziptied the check valve into the tube.
Can anyone elaborate as to why PCV connects to vacuum from two separate locations, ie the throttle body and the manifold? Is the throttle body vacuum connection outside of the throttle plates, thereby at less vacuum than the direct manifold connection in order to maintain a difference in pressure between the two valve covers, but overall to lower the delta between them vs atmosphere?
Old Jun 8, 2020 | 12:08 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
The pass valve cover line is indeed ported to the front of the t-body blades. It supplies filtered air to the crankcase that is removed by the pcv on driver side.
Old Jun 8, 2020 | 12:35 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
I delete all that and run breathers only unless its spitting oil then run to catch cans
slickrock55
Jun 9, 2007 04:03 AM
MrDude_1
Aug 26, 2004 06:35 AM
gta324
Mar 12, 2004 02:16 PM
AC
May 6, 2003 02:43 PM
a73camaro
Feb 11, 2002 05:45 PM
