New starter not reliable
Old Jun 7, 2020 | 06:19 PM
sunbound's Avatar
Car: 1987 IROC-Z
Ok, so I just replaced the old starter with a new one. The new one, mounted up doesn't start reliably. It takes 2 or three times for it to start. On the times that it doesn't start the engine, it does sound like it's engaging, but doesn't turn the engine. Release the key, try again, usually by the 3rd time, it starts.
Any tips on this?
Thanks guys
Old Jun 8, 2020 | 05:33 AM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: New starter not reliable
sounds like a bad starter. The starter gear may turn but isn't kicking out to engage the flywheel
Old Jun 8, 2020 | 06:13 AM
OrangeBird's Avatar
Car: 1989 Firebird
Any tips on this?
Thanks guys
Before you condemn the starter I must ask , did you follow the proper "shimming" procedure when you installed it ?
A starter not properly shimmed could result (if the fit is too tight VS too loose) in the starter gear not traveling quite far enough to be fully engaged with the ring gear , resulting in the starter motor not turning as you describe .
Old Jun 12, 2020 | 08:16 AM
sunbound's Avatar
Car: 1987 IROC-Z
The starter didn't come with any instructions. At first, the starter just clicked, it wouldn't engage. I added both shims that came with the starter, and I get this result.
What procedure would you suggest?
Old Jun 12, 2020 | 08:43 AM
The procedure that involves taking it back to the store and exchanging it for one that works.
Old Jun 12, 2020 | 10:23 AM
Drac0nic's Avatar
If the old starter didn't work and this starter didn't work I'd be checking the ground from the battery to the block before I went much farther.
korialtraz
Mar 14, 2012 12:17 AM
vonbeck265
Aug 4, 2010 03:13 PM
webcat
Jan 9, 2010 07:48 PM
9tr3g
Dec 31, 2008 02:19 PM
Matthew91-Z28
Jul 11, 2007 05:47 PM
