knock sensor help a.s.a.p
Old Jan 14, 2002 | 04:08 PM
88NOSTA's Avatar
what side dose it go on in a 88 ta 305
Old Jan 14, 2002 | 04:43 PM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
Right above the oil pan rail on the passenger side.
-Rich-
Old Jan 14, 2002 | 08:57 PM
88NOSTA's Avatar
what wire is it the white or black they both have the same plug for the knock sensor
Old Jan 14, 2002 | 09:06 PM
SMasterson's Avatar
Car: '89 GMC Pickup
Engine: 383 SBC Stealth Ram
Transmission: 700R4/VIG 3200
It's the white wire for the knock sensor.
The black one is most likely for the auxiliary fan (fan2) control. It plugs in on the head between 6&8 cylinders. It comes on if the temperature get VERY high, or when the AC is turned on. I seem to remember the connectors being similar but a different color.
Old Jan 15, 2002 | 12:11 PM
88NOSTA's Avatar
ok cool thanks guy's. i tryed to remove the plug that the rebulid shop put in and it striped the head out there is a plug in the other side that i got out will it be ok the use that hole for the knock sensor it's in the same place as the other one and it bolts right in. let me know
L98GTA87
Oct 19, 2015 10:43 PM
cking99
Sep 22, 2015 11:33 AM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
BLK87Z
Sep 18, 2015 11:29 PM
FormulasOnly
Sep 10, 2015 09:07 PM
