Transmission rough or misfire
Old Jun 13, 2020 | 05:10 PM
zupta82's Avatar
Car: 88 Trans Am
Engine: 305 TBI
Axle/Gears: 3:42 open diff
I just rebuilt my transmission. On the transmission forum I have detailed info of my progress. The car is shaking when put into gear, under the hood it appears to be a smooth idle and it’s starts quick can misfires cause messed up shift points especially in 1st and 2nd gear. I don’t feel any slippage( as in rpms fluttering when shifting). There is hesitation even before 1st shift even starts
Old Jun 13, 2020 | 07:07 PM
zupta82's Avatar
Car: 88 Trans Am
Engine: 305 TBI
Re: Transmission rough or misfire
Off the line is when I feel the stumble the most it is hesitating could even one of wires crossed cause it to still run
Old Jun 14, 2020 | 08:44 AM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Could be. Easiest way to find out is to pull plugs and look to see if anything seems odd. Ign wire arcing somewhere or a fouled plug. Being TBI, it's less likely to be a fuel issue like an individual injection.
Old Jun 14, 2020 | 06:31 PM
zupta82's Avatar
Car: 88 Trans Am
Engine: 305 TBI
Here is some pics of the plugs I’m still having problems. I smell burning metallic smell almost a caustic smell, it’s got to be running lean
Old Jun 14, 2020 | 06:32 PM
zupta82's Avatar
Car: 88 Trans Am
Engine: 305 TBI
I replaced all of them
Scorched1984
Jul 22, 2016 02:04 PM
formula_novice
May 30, 2010 09:16 AM
eInfoHost
May 13, 2003 10:49 AM
