transmission shift question
Old May 29, 2010 | 09:38 AM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Hi Guys,
I manually put my transmission into 1st gear and then rev it until about 5500rpm... but before I can shift it up into 2nd gear, it shifts on its own! What would cause this? A weak component?
Any info would be appreciated.
Thanks!
Old May 30, 2010 | 04:43 AM
Pro Built Automatics's Avatar
Re: transmission shift question
All stock 700R4's do this. The TransGo Performance Shift kit allows you to hold 1st gear to any rpm. I carry the modified version of these.
Old May 30, 2010 | 09:16 AM
Thanks for the reply! So will it shift up thru all gears like this? Or is it just first? I thought the point of putting it manually in 1st is so it won't shift up?
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Cleotiz
Jan 6, 2018 08:56 PM
BlackphantomZ28
Apr 24, 2016 08:14 AM
redmaroz
Aug 16, 2015 11:40 PM
mizz0313
Aug 12, 2015 06:45 AM
