85 305 bracket setup
Old Jun 14, 2020 | 03:00 PM
Tim Doyle's Avatar
So i just bought a 85 305 carb and i wanted to upgrade the cam since i had one laying around and thought it would be a nice little upgrade before i pull the 305 out and drop in a bigger motor. I put in new timing chain and cam. also changed the intake and put headers on. Now i am at a loss on how the AC,Power steering brackets line up and how they go. i have been trying to understand where it all goes but have failed every time. I should have taken a picture of what it used to look like so i could copy. But i didn;t and now i need some help. Could someone send me a picture of there stock 1985 V-belt setup with AC. i need driver side multi-angles. Thank you
Old Jun 14, 2020 | 05:12 PM
NoEmissions84TA's Avatar
Re: 85 305 bracket setup
You have created more problems than you solved if you installed a performance cam without upgrading the valve springs.
But to answer your question about the belt diagrams.............
Blue1990camaro
Dec 18, 2013 05:55 PM
ThomasJ
Jan 27, 2011 10:42 PM
formula5
Sep 7, 2001 12:23 AM
