84 Camaro has .3 amp drain on battery with key off
Old Jun 23, 2020 | 11:33 PM
giovanhalen's Avatar
Car: 1984 Z28
Engine: 454
Transmission: Th400
If I pull the fuse that the interior lights and horn are on the drain goes away. What else is on that circuit?
Old Jun 23, 2020 | 11:56 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: 84 Camaro has .3 amp drain on battery with key off
Might vary by vehicle, year, and options. Tell people what you've got and somebody might toss an electrical schematics your way.
Old Jun 24, 2020 | 02:02 AM
Car: 1984 Z28
Engine: 454
Transmission: Th400
1984 Z28, originally a manual shift car. Now has a carbureted bbc, th400, and 9".
Old Jun 24, 2020 | 07:04 AM
Aftermarket alarms & stereos often get wired to that circuit one way or another. Anything of that sort, you will largely have to track down yourself.
Old Jun 24, 2020 | 12:34 PM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
If the car is no longer stock, no one here is going to be able to offer step-by-step troubleshooting. You're going to have to get a copy of the factory wiring diagram (a search of this site should turn one up ), and track that circuit down section by section, starting at the fuse block, one wire and connection at a time until you find what's causing the current drain.
Old Jun 24, 2020 | 01:05 PM
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
Do you have a dash cam, USB charger, bluetooth device or some other accessory plugged in?
oifivveteran
Aug 10, 2010 03:30 PM
ad356
Dec 2, 2007 05:23 PM
GTA88
Apr 13, 2004 06:51 PM
TallWhiteGuy
Car Audio
Dec 29, 2002 07:18 PM
pookey
Car Audio
Mar 4, 2001 04:29 PM
