Crank but no start
Old Jul 12, 2020 | 04:09 PM
isaiah04's Avatar
Car: 1988 firebird
Engine: 305 TBI
Crank but no start
88 Firebird with a TBI 305, was running before but now i cant get it to start.
It has a new ECM, distributor, fuel injectors, starter and battery, it cranks over very slowly, but stops cranking and makes a rapid clicking sound. I have spray from the injectors and should have spark because i have all new ignition parts.
Old Jul 12, 2020 | 05:19 PM
Re: Crank but no start
Rapid clicking sound = bad connection at a battery cable or internal to the battery
Check your cables. Both ends of both cables. Make sure the black one is bolted securely to the block or whatever it goes to; make sure the red one is bolted securely to the starter. Take both of em loose from the batt and clean em by dunking in a solution of about 2 tablespoons of baking soda (sodium bicarbonate for all you chemists out there) in 6 oz of HOT (as near boiling as possible) water. Take a wire brush to the batt terminals themselves while the cables are off, and clean em up with a wire brush, then douse em with the baking soda solution and a paintbrush. Rinse everything thoroughly with clean fresh water (garden hose) and reassemble. You may find that one of your batt cables, or maybe even both, are bad, where the wire goes up into one of the ends. Replace if necessary,
Old Jul 16, 2020 | 09:54 PM
isaiah04's Avatar
Car: 1988 firebird
Engine: 305 TBI
checked all my grounds and they were terrible. started right up after
Hawkeye1980
May 25, 2014 01:55 PM
jeep6981
Mar 2, 2009 11:33 PM
runitintotree
Nov 4, 2006 04:28 PM
xz510
Nov 14, 2005 01:43 AM
