fpr mounting location 91(carbed)
Old Aug 22, 2020 | 03:42 PM
zrafferty's Avatar
so been working on car found fuel running at 9psi with edelbrock carb.
adding a fpr and an fittings.
I cannot find a decent and safe place to install my new fpr I prefer in firewall but have ac system and blower stull installed qhere do you guys install yours at that is safe not too close to spark or heat.
Old Aug 22, 2020 | 04:14 PM
Re: fpr mounting location 91(carbed)
IMO the best place is actually up front, somewhat near the stock mech FP. The lines are already right there to hook up to it.
Old Aug 22, 2020 | 04:31 PM
zrafferty's Avatar
Talking about right on frame rail?
Old Aug 22, 2020 | 04:40 PM
zrafferty's Avatar
I know I was looking more around battery or in back under hinges but would have to unmount to readjust the fp which isn't too bad but rather have easy assess until i have that sweet spot.
summit stated its calibrated at 6.5psi which is high end max for edelbrock.
by battery i would have fpr in way if battery has to be pulled.
May do it under the hinge and drill out one of the holes to pass my Allen key through
Old Aug 22, 2020 | 06:54 PM
Yes I think the frame rail, kind of next to the fuel pump or maybe a bit forward from there, is probably the best spot. Right where the lines are; out of the way of exhaust; not totally convenient for adjusting, but once you get it set where it needs to be, pretty functional overall.
shawnrs
Carburetors
Jun 30, 2013 12:24 AM
camarocasanova
Carburetors
28
Feb 18, 2012 09:51 PM
dwillms
Jul 3, 2004 03:39 AM
weberusn
Jun 29, 2004 10:49 PM
mcconahay37
Carburetors
Aug 15, 2001 08:13 AM
