Fuel tank vent valve cap repair (fabrication).
Old Aug 29, 2020 | 06:20 PM
GeneralDisorder's Avatar
I've been meaning to do something about this situation for a while. I decided to spend a couple hours this morning and make a new bottom cap that bolts to the bracket instead of clipping in - out of 6061 aluminium. And of course cleaned and inspected the guts and top cap - which were all in fine condition on this valve. I made about a 0.005" snap fit with the plastic top hat so once it's pressed below the lip it won't easily come out without some twisting and force applied:
No there's no plans or dimensions for this. I just made it up as I went with careful measurements. If there is enough interest I might have access to a CNC where some of these could be spun up. But if you have a lathe it's not all that hard to do a one off either. I probably have 4 hours into this one and it wouldn't be worth the labor to sell them making them by hand.
GD
Old Aug 30, 2020 | 01:47 AM
Fire"Dutch"Bird's Avatar
Car: '88 Firebird Formula 350
Engine: 350 (5.7 TPI)
Transmission: auto 700R4
Axle/Gears: BW 9-bolt L.S.
Re: Fuel tank vent valve cap repair (fabrication).
Great job!
I like to have one, if possible...
Old Aug 30, 2020 | 06:49 AM
battmann's Avatar
Engine: LG4 / turbo LQ4
Transmission: 700R4 / 4L80E
That’s pretty sweet
Old Aug 30, 2020 | 09:44 AM
www.emachineshop.com
Not cheeeeep, but quite effective.
Old Aug 30, 2020 | 08:37 PM
Oh that's an interesting option!
One of my business partners has a friend that has a HAAS CNC machining center that is just sitting doing nothing (he is of the "independently wealthy" category and it just sits there in one of his warehouses)..... so I could likely spin some of these up. Cost TBD, Certainly depends on how many I make. Could likely make the whole housing with the power of that unit. But from what I have seen the problem is the lower cap where the tabs break off.
GD
tonys91rs
Feb 5, 2018 06:41 PM
Davidgou
May 31, 2017 07:23 PM
BADNBLK
Sep 3, 2013 05:41 AM
Psycho_91Camaro
Dec 10, 2006 08:51 PM
Calderone
Jan 21, 2004 07:36 PM
