Melling 22280 vs LT4 Hot Cam
Car: Dad's 87 Bird (Org Owner)
Engine: Vortec 350 Crate Motor
Transmission: TH350
Axle/Gears: 3.42 Posi
Has anyone tried the Melling 22280 cam. Very similar specs to LT4 Hot Cam, but, for almost half the price. I have found it for $187 with free shipping. Brand:Melling
Manufacturer's Part Number:22280
Part Type:Camshafts
Product Line:Melling M-Select Class 2 Camshafts
Summit Racing Part Number:MEL-22280
UPC:00729295513179
Cam Style:Hydraulic roller tappet
Basic Operating RPM Range:2,000-5,000
Intake Duration at 050 inch Lift:220
Exhaust Duration at 050 inch Lift:224
Duration at 050 inch Lift:220 int./224 exh.
Advertised Intake Duration:283
Advertised Exhaust Duration:287
Advertised Duration:283 int./287 exh.
Intake Valve Lift with Factory Rocker Arm Ratio:0.495 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio:0.502 in.
Valve Lift with Factory Rocker Arm Ratio:0.495 int./0.502 exh.
Lobe Separation (degrees):110
Computer-Controlled Compatible:No
Valve Springs Required:No
Brand:Chevrolet Performance
Manufacturer's Part Number:24502586
Part Type:Camshafts
Product Line:Chevrolet Performance LT4 Hot Cam Hydraulic Roller Camshafts
Summit Racing Part Number:NAL-24502586
Basic Operating RPM Range:1,800-5,800
Intake Duration at 050 inch Lift:218
Exhaust Duration at 050 inch Lift:228
Duration at 050 inch Lift:218 int./228 exh.
Advertised Intake Duration:279
Advertised Duration:279 int./287 exh.
Intake Valve Lift with Factory Rocker Arm Ratio:0.492 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio:0.492 in.
Valve Lift with Factory Rocker Arm Ratio:0.492 int./0.492 exh.
Lobe Separation (degrees):112
Valve Springs Required:Yes
Quantity:Sold individually.
Part Type:Camshafts
UPC:00729295513179
Part Type:Camshafts
Car: 1983 G20 Chevy
Transmission: 4L60
Re: Melling 22280 vs LT4 Hot Cam
Part Type:Camshafts
UPC:00729295513179
Part Type:Camshafts
Part Type:Camshafts
UPC:00729295513179
Part Type:Camshafts
