Spring Recomendation for Lunati Cam
Old Mar 30, 2007 | 07:23 AM
kelham's Avatar
Car: 87 TA / 87 Firebird
Engine: 385 FastBurn / Performance 3.4L
Transmission: TKO600 / 700R4
Axle/Gears: Ford 9" / GM 10bolt
Can anyone recomend a good spring # for the heads to help pull enough power out of lunati cam #SM-225.
Its for a chevy 305 SB w/ Fuel Injection
Also what Rockers would you recomend 1.5.1 or 1.6.1 w/ 5/16 pushrods
Brand: Lunati
Product Line: Lunati Hydraulic Flat Tappet Camshafts
Cam Style: Hydraulic flat tappet
Basic Operating RPM Range: 1,800-5,800 RPM
Intake Duration at 050 inch Lift: 225
Exhaust Duration at 050 inch Lift: 225
Duration at 050 inch Lift: 225 int./225 exh.
Advertised Intake Duration: 275
Advertised Exhaust Duration: 275
Advertised Duration: 275 int./275 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.477 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.477 in.
Valve Lift with Factory Rocker Arm Ratio: 0.477 int./0.477 exh. lift
Lobe Separation (degrees): 108
Intake Valve Lash: 0.000 in.
Exhaust Valve Lash: 0.000 in.
Computer Controlled Compatible: No
Grind Number: SM-225
IM still learning, b/c im starting my engine build this summer before I go to college, would like to get it done before I turn 19.
Thanks for the input
Old Mar 30, 2007 | 07:10 PM
Rob Wade's Avatar
Car: 89 jaguar xjs convertable
Engine: 89 L98 5.7 TPI
Axle/Gears: 3.23 dana 44
Re: Spring Recomendation for Lunati Cam
I would call Lunati
Jorlain
Oct 8, 2015 01:57 AM
86CamaroDan
Sep 29, 2015 10:08 PM
Strick1
Sep 4, 2015 07:11 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
z28guy134
Sep 1, 2015 11:50 PM
