set timeing
Old Jan 15, 2002 | 12:22 PM
88NOSTA's Avatar
set timeing
how do i set the timing i cant tell if the #1 cylinder is up
Old Jan 15, 2002 | 12:45 PM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
Easy way to tell if #1 is at TDC of compression stroke.Take out the spark plug,stick your finger in the hole and have someone bump the motor.When your finger gets blown out of the hole,bump it far enough to line up the mark on the balancer with the pointer.Then drop the distributor in, with the connectors on the driver's side.This should gat you close enough to start it and put a timing light on it.
-Rich-
specialized
Jun 18, 2022 09:26 AM
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Andrew6.688
Dec 13, 2015 10:59 AM
Mutillator
Exterior Parts for Sale
Oct 1, 2015 06:05 PM
