Scat 9000 series 383 cranks
Car: 1987 Z28 IROC
Engine: 6.2L
I'm looking to build a 383 stroker. I've built a few SBF strokers but know nothing about SBC.
This is to be a lower RPM mid power level (400-450hp) TPI build with 700r4 transmission.
I've come across a scat crank but am confused by what it requires.
https://www.jegs.com/i/Scat/942/935050L/10002/-1
The details are:
Balances at 1830 to 1850 grams with standard weight flywheel, neutral standard balancer, and one-piece mallory (i.e. heavy metal) in counterweight.
Is this common?
On SBF engines they are commonly balanced external either 28oz or 50oz.
On my sbc I want to build it will have stock type balancer and flexplate.
I want to make sure everything works together.
The details are:
Is this common?
Car: 1987 Z28 IROC
Engine: 6.2L
Re: Scat 9000 series 383 cranks
I guess what I am trying to get at and do is assemble a stroker kit for half the cost of a purchased kit.
The 3.75" stroke crank - $240
Summit stroker pistons - $160
Main/connecting/cam bearings - $75
Rings - $20
Re-use stock connecting rods
The internal/external balance is what is confusing me on what I need.
Rings - $20
Car: 1983 G20 Chevy
Transmission: 4L60
Rings - $20
Rings - $20
I would have a machine ahop balance it. My Scat crank had to be drilled in a few places and have 2 pieces of mallory metal added to balance correctly with my 6" rod 383. I would get the connecting rods brushed and use full floating pistons but that is just me.
Car: 1987 Z28 IROC
Engine: 6.2L
1 piece rear seal SBC engines are internally balanced on the front and externally balanced in the rear. Flexplate or flywheel is counterweighted.
