3.1 V6 camaro
Old Nov 23, 2020 | 01:25 AM
dramos116's Avatar
3.1 V6 camaro
I recently did a spark plug change on my 91 camaro and now it won’t start, it ran perfectly fine before the change. I also got brand new wires. I tried seeing if it was the firing order but i tried 3 different orders but none of them worked expect one where the engine would turn on then would shut off on its own and the exhaust would back fire a lot. It’s been sitting for about a week and I have no clue what it could be, please help i only owned this car for about a month before this happened
Old Nov 23, 2020 | 03:52 AM
J.C. Denton's Avatar
Car: 85 Iron Duke, 88 GTA and 92 TA
Re: 3.1 V6 camaro
Are you absolutely sure you tried the correct firing order? For the V6 it is 1 - 2 - 3 - 4 - 5 - 6.
Old Nov 23, 2020 | 07:07 AM
Whitebird75's Avatar
Car: 1988 Pontiac Firebird
Engine: 2.8 L V6
Re: 3.1 V6 camaro
For Reference, the passenger side cylinder head is the #1 spark plug, unlike a standard Small Block or Big Block. Make sure you disconnect the timing plug on the fire wall before adjusting the timing. Spec is 10* BTDC.
JesseMorrow
Jul 12, 2019 09:32 AM
Jbeal57
Jul 17, 2015 12:40 PM
oilfieldtrash7
Apr 16, 2012 05:06 PM
Timmie
Apr 5, 2012 03:17 PM
