2.8 v6 firing order
Old Jun 19, 2019 | 07:15 PM
JesseMorrow's Avatar
2.8 v6 firing order
I have an 88 Camaro and I am having trouble with the firing order. From what I have seen, it is 1-2-3-4-5-6 but since I changed it to that it has only gotten worse. Before I could get it to start but it took a few seconds and would die if it wasn't getting fuel but now it will not start at all.
Old Jun 20, 2019 | 08:23 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
Re: 2.8 v6 firing order
1-2-3-4-5-6 is correct. Double check your wires on the cap and make sure your timing is correct.
And yes, it will die if it's not getting fuel, regardless of timing.
Old Jun 20, 2019 | 08:43 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Note that on the 60° V6 engines #1 cylinder is the right front. That is on the passenger side.
RBob.
Old Jul 12, 2019 | 09:32 AM
Sierra6's Avatar
Car: 1985 Firebird
Engine: 3.4 turbo
RBob.
always confused me, because when you're actually working on it, it's on the left and vice versa.
Steve00YZF
Jun 11, 2001 06:02 PM
Blucamaro
Mar 14, 2001 08:00 PM
bleak
Dec 7, 2000 07:53 PM
Mike '91 Z28
Oct 7, 2000 11:46 AM
MY Z ROCS
Jul 28, 2000 09:31 AM
