1992 RS. only starts when it wants to. Had to put a external push button switch. HELP
Old Nov 24, 2020 | 12:50 PM
snowflake's Avatar
Car: 91 camaro
Transmission: auto
Axle/Gears: ????
Sometimes the key works and sometimes it dont. I had to put a push button starter switch to start it most of the time. Any idea's.
I took it to a electrical shop That I know is good, and he could not figure this out.. Has this happen to anyone? Please help. Thanks
Old Nov 24, 2020 | 12:56 PM
snowflake's Avatar
Car: 91 camaro
Transmission: auto
Axle/Gears: ????
Re: 1992 RS. only starts when it wants to. Had to put a external push button switch.
EDIT
Old Nov 30, 2020 | 03:54 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Gentlemen, Press Your Pushbuttons !
Sounds like you fixed it.
The starter wiring, along with most other wire sizes were chosen by a cheapskate.
The bad selections made by "engineers" cause a lot of people to throw away $$$$ on unneeded batteries.
Their cheapskate choices cause voltage drops and other problems in cars.
In my cars I have increased the wire sizes in the Starter, Fan, Blower, Rear Defog, and other circuits.
It greatly improves the performance of those systems.
Happy Racing!
Normal Cars: Refueling Takes Seconds.
Electric Cars: Recharging Takes HOURS, Which One Makes More Sense?, You Do The Math
Old Nov 30, 2020 | 04:27 PM
snowflake's Avatar
Car: 91 camaro
Transmission: auto
Axle/Gears: ????
Nope, not fixed!! I need help here LOL
Old Nov 30, 2020 | 05:17 PM
LikeARock47's Avatar
Ignition switch. If the external push button start you added works every time, then it's most likely the "start" circuit contacts the ignition switch failing. Causes an intermittent no start like you have and just keeps getting worse. A lot of times, giving the steering column shaft a good whack with your hand will make it work again (briefly), on our cars you'd have to remove the under dash panel to do that.
Fairly common problem across various GM cars from the 80s and 90s that all used that same steering column. It's not fun to fix, the ignition switch is mounted directly on top of the column down near the floor. Some people say they have replaced it without dropping the column down, but I never could. So plan on having to do that.
camaro_lover92
Aug 10, 2013 10:10 PM
jetrebel
Jan 28, 2010 01:58 PM
redrotorR1
Mar 27, 2003 08:53 AM
