Map sensor vacuum goes to throttle body? 350 tpi swap
Old Dec 1, 2020 | 02:58 PM
88irocz91rally's Avatar
Car: 1988iroc z and 1991 Camaro Rs
Transmission: 4 speed and 5 speex
91 RS was a 305 tbi did a 350 tpi swap from a 88 it is a speed density swap as well , I am trying to sort out some small details it's running on it's own pretty good thought it had a high idle 1500 but I think the tach is off it might actually be more close to normal , anyways sometimes it surges rpms go up on there own and down , getting a code 33 and 42.I did notice the map sensor has a vacuum port on it is this spose to plug into throttle body? Mine is from a 88 maf car I don't see anymore ports to use?
Map sensor port
Old Dec 1, 2020 | 03:32 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: Map sensor vacuum goes to throttle body? 350 tpi swap
Egr solenoid went to the tb. The map went to one of 3 port on the p/s of the plenum. Looking at it, your plenum looks to only have 2. Originally a maf plenum?
edit, scratch that last question, I just reread your post. Yes, being 88 it was maf, you'll need to add a port to maintain everything the factory has. I had a 89 plenum that I added the port.
the original SD plenum also has more material and a bolt hole to attach the map sensor bracket
Old Dec 1, 2020 | 05:15 PM
Oh ok, I was suspecting that wanted to verify, thanks so much!
TraviZ
Apr 2, 2008 03:58 PM
1990GTA
Feb 13, 2006 03:12 AM
Scamo-2.8
Jul 31, 2005 11:36 AM
resqbubba
Nov 14, 2004 07:36 PM
Buck268
May 23, 2003 01:37 PM
