quick map sensor help
Old Jul 26, 2005 | 09:02 PM
Scamo-2.8's Avatar
Car: 1989 Camaro RS
Engine: 1990 - 5.7
Transmission: Tremec 3550
Axle/Gears: 9 Bolt - 3:45
Hello all,
I have installed a 5.7 from a 90 camaro in my 89 2.8 and I'm just wondering where the vaccum hose goes from the map sensor. Does it tee into the hose that runs from the EGR sol to the throttle body? The vaccum diagrams just don't show it properly. Thanks.
Old Jul 31, 2005 | 11:36 AM
Vader's Avatar
DO NOT connect it to the vacuum port on the throttle body. That port is a timed vacuum port, and only provides partial vacuum after a specified throttle opening is reached. There is supposed to be no vacuum at that port with the throttles in the closed position.
Connect the MAP line directly to the plenum. Tee off the FPR or HVAC vacuum fitting if necessary.
gta892000
Aug 11, 2019 11:16 AM
Twin_Turbo
Mar 14, 2016 10:10 PM
customblackbird
Oct 1, 2015 04:30 PM
corey8084
Sep 17, 2015 02:56 PM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
