Help! With timing
Old Jul 27, 2005 | 11:23 AM
Tha_Villain's Avatar
Car: Camaro RS
Engine: 2.8 L
Help! With timing
Ok heres the problem I cannot adjust timing properly on this car whatever I set it to, engine runs rough. I did all the proper steps however when I disconnect the SPOUT switch car runs much smoother and better. So at this point I'm driving with it disconnected. Could the ECM be faulty or something?
Old Jul 31, 2005 | 11:39 AM
Vader's Avatar
You must be working on a Ford if you have a SPOUT connector. GM systems use an "EST Bypass" connector.
If you are setting the base timing with the bypass connector disconnected, that's the correct procedure. Set it at 6° BTDC and let the ECM and EST do the rest. If there is a problem with this, start analyzing the EST system. The detonation sensor and its wiring are the first suspects.
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
