Prime Engine (turn oil pump which way) ?
Old Jul 31, 2005 | 02:27 AM
Orizon's Avatar
Car: 1984 Trans Am
Engine: BuiLt 350! Hooker 2055's
Transmission: T5-manual trans-centerforce clutch
when primeing engine with tool, on sbc 350 if that matters (doubt it) do you turn it forward or reverse on drill, clockwise or counterclockwise, thanks.
Old Jul 31, 2005 | 06:14 AM
ede's Avatar
ede
cw is all i ever used since my biggest 2 drills don't reverse. most drills don't have enough *** to move the oil. on a SBC if you fill the pan with oil the pump will prime it's self. if you use assembly lube during assembly you'll not have problems with dry strats, the oil will get where it needs to go. priming a SBC is mostly a feel good thing for most people.
Old Jul 31, 2005 | 11:53 AM
Orizon's Avatar
Car: 1984 Trans Am
wow, thanks for the info, engine was built by a machine shop and it was mentioned he uses the good asembly lube but its been like 8 months sitting in my garage since i got it so ya just a feel good thing i suppose illl prime it ;0
Frozer!!!
Jan 19, 2024 04:55 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Navy8125
Aug 21, 2015 09:32 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
djmarch
Aug 9, 2015 05:27 PM
