lift on stock springs
Old Jan 16, 2002 | 01:02 AM
Momar's Avatar
I was wondering how much lift could be run on stock style valve springs?
Ben
Old Jan 16, 2002 | 07:15 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
upto .48 is normally ok..
.49 is pushing it.
Old Jan 16, 2002 | 10:35 PM
Vader's Avatar
There is a lot of variance in "stock" springs, and a lot of variables that determine what is safe. Aside from the simple mechanical binding point of the coils at a given lift, there are other factors to consider. Just because the coils don't bind at 0.480" lifts doesn't necessarily mean that stock springs are adequate for a particular engine.
Typical stock valve springs have a closed seat pressure under 85 lbs. This might be enough for smaller diameter valves at low RPMs with a relatively mild cam profile. Increase the valve mass, engine RPM, acceleration rate (lobe ramp), lifter mass, rocker design, and the low pressure stock springs can start to lose control of the valve train. This can mean anything from power loss due to valve float at higher RPMs to valve spring failure with catastrophic damage as a result.
It's all a necessary part of selecting the appropriate camshaft and components to suit the engine and its intended use. Stock springs at 0.480" lifts in a stroked truck-pulling engine might be adequate. A higher RPM, large valve street/racing engine might not fare too well with them, however.
Old Jan 18, 2002 | 04:06 PM
ede's Avatar
ede
.46 is my limit, actually i most always change springs when i change a cam, even if the springs are a stock type replacement.
customblackbird
Aug 15, 2021 10:16 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
gta90
Sep 15, 2015 04:00 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
anesthes
Aug 8, 2015 09:37 PM
