2.8 v6 wont run
2.8 v6 wont run
hey i have a 1987 Camaro RS with the 2.8 V6 and im having problems with it running it starts up super quick but then dies ive changed alot of things including the fuel pump i just cant keep it running. any ideas of what it might be?
Car: 1990 firebird,1989 Iroc z,1986 fire
Engine: 3.1lt,5.7tpi,3.1mpfi
Transmission: auto,auto
Axle/Gears: 273?277
Re: 2.8 v6 wont run
Just because you changed the pump doesn't guarantee everything is connected right. Go through the fuel pressure test procedure. I've had bad new pumps and split rubber connecting hose. I've forgotten to reconnect the harness to the sending unit. Also the fuel pressure regulator can go out.
Axle/Gears: 273?277
Re: 2.8 v6 wont run
Make sure that pressure is right.. your not having a vats issue are you
dumb me. You probably won't have vatts in a 87 with the 2.8
