Help! I have no brakes!
Old Jan 16, 2002 | 12:31 PM
Drylar's Avatar
Hrm. This is what happened:
I was driving home at 2am and went to stop for a light. My brakes went mush. They barely slowed the vehicle. I blew the light and let it coast to a stop.
What I have done:
Since the brake system was working, i checked and saw the master cylinder down a bit. I refilled it, which didn't work. I figured that it had air in the system, since I can get some, however little, brakeing action. I bled the entire system, master cylinder and all. Still nothing. When I was bleeding it, I noticed something odd... When the peddle was getting tight, it never got 'rock hard'. Nor did it ever 'give a little' when the valve was opened.
What was done within the last 6 months:
I replaced brakepads on all 4 wheels 4 months ago. I also reran one of the small rubber hoses to the caliper (my friend helping tore it when they let the caliper hang).
Car:
'86 Camaro Z28 Engine LB9 Same brakes all around, so guess they are all disc (they all take pads and have the same calipers)
What can I do to get this thing road worthy again? I am without a car right now.
Old Jan 16, 2002 | 01:08 PM
Drylar's Avatar
Please help me, as it is my daily driver and I need this thing road worthy. What parts can be defective and or need replaced?
Old Jan 16, 2002 | 01:20 PM
rezinn's Avatar
So you have pressure, the brake pedal is not mushy anymore?
How about the booster? Is it getting adequate vaccuum?
Old Jan 16, 2002 | 01:22 PM
Drylar's Avatar
Booster is woking, and has a vaccum. The pedal got tighter (not fully tight) when pumped during bleeding, but when it was started again, it went out. Back to mush.
Old Jan 16, 2002 | 01:43 PM
rezinn's Avatar
Sounds like you have a leak somewhere. I'd try bleeding again and check. Something inside the master cylinder could have broken possibly.
BADNBLK
Convertibles
Sep 21, 2015 07:56 PM
dbrochard
Sep 19, 2015 08:13 PM
Necron
Brakes
Sep 14, 2015 12:45 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
