Where is the best spot to place a smoke machine?
Old Apr 2, 2021 | 09:04 AM
88BLKTransAmGTA's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7 L98
Axle/Gears: 3.77
Where is the best place to connect the smoke machine to test for vacuum leaks on a 88 5.7 TPI? Just any vacuum hose end?
Old Apr 2, 2021 | 12:55 PM
GeneralDisorder's Avatar
Re: Where is the best spot to place a smoke machine?
Spray around with some brake cleaner - when the engine speeds up and smooths out you found it.
Smoke machine can be hooked to any vacuum port under the throttle blade.
GD
Old Apr 18, 2021 | 04:39 PM
rick90gta's Avatar
Car: 1990 GTA
Engine: 5.7L TPI SLP Runners Accel 24lb Inj
Transmission: 700R4 Upgraded Internals, Shift Kit
Axle/Gears: Borg Warner 9 Bolt, 3.27 Ratio
I like to use the canister vent line if available, or the map sensor port
Bobby_80s
Feb 24, 2011 02:35 AM
mgray1982
Sep 27, 2008 01:39 PM
MarkMueller
May 17, 2006 03:30 PM
88transam5.0
Apr 17, 2001 02:21 PM
