Sanity check?
Old Apr 18, 2021 | 04:17 PM
rick90gta's Avatar
Car: 1990 GTA
Engine: 5.7L TPI SLP Runners Accel 24lb Inj
Transmission: 700R4 Upgraded Internals, Shift Kit
Axle/Gears: Borg Warner 9 Bolt, 3.27 Ratio
Sanity check?
Building a new engine combination:
TPIS Miniram
TPIS 58mm TB
​​Comp 280xfi cam
​​​​​LS7 lifters
AFR 195 heads (?) TBD
Lunati Voodoo 3.75 crank
GM 10105123 bare block (clearanced, oil system mods)
6 in h-beam capscrew rods, brand TBD
forged pistons, brand TBD
EFI Connection 24x system w/cover mount cam sensor
MSD oil pump drive
canton oiling system
Dyno Don headers
3.5/4in exhaust TBD
I'm thinking this setup should be good for well north of 450 fwhp, my main concern is the block, specifically the main caps holding up. Does anyone have real world experience they'd like to share? I'm looking at the dart shp as an alternative but I'm so close to starting the build I don't relish the idea of putting it off until summer if the oe style block will work! Also seeking opinions on afr 195 vs 195 comps vs tfs 195 for my app. Application is mostly street with a few track days at gingerman here in MI per season. Car is 1990 GTA with a t56 and all the normal suspension/brake/tire upgrades. First time doing a sbc to this level, but have plenty of experience with ls-based stuff. Just want to do a moderately strong sbc because that's what the car came with and I like the challenge. I know you can get 470 hp out of a ly6 with a cam swap, lol, just not ready to ls swap the old girl. Maybe next build
thanks in advance!
Old Apr 22, 2021 | 07:13 AM
rick90gta's Avatar
Car: 1990 GTA
Re: Sanity check?
Bueller?
Old Apr 22, 2021 | 06:17 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: Sanity check?
That kind of flywheel HP on a modern GM block isn't a big deal. Good hardware and good machining and clearances, you should have little issue.
Old Apr 23, 2021 | 11:50 PM
rick90gta's Avatar
Car: 1990 GTA
Re: Sanity check?
my thoughts and my machinists as well, but I've seen some pics of wiped mains on these blocks with higher horsepower/rpm builds. Thanks for responding, just hoping to find a sounding board before I finalize the plan and commit to my choices
180pruf
25
Nov 10, 2012 07:39 PM
19Irocz86
Mar 6, 2007 11:03 AM
cyclops2
Jan 10, 2004 02:58 PM
BigL350
Apr 26, 2003 07:39 PM
aziroc
Jun 12, 2001 10:07 AM
