Backfiring after tune up
Old Apr 21, 2021 | 07:35 PM
Ken56's Avatar
Car: 1989 trans am gta
Engine: 5.7 350 crate
Transmission: Automatic
Axle/Gears: N/A
So we did a slight tune up in my 1989 trans am gta. just put in new spark plugs, cap, and rotor. Started the car and noticed it started backfiring while idling. Checked oil and noticed just a couple tiny pieces of metal. Any idea what would cause this?
Old Apr 21, 2021 | 08:13 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: Backfiring after tune up
Recheck wires, you probably have some mixed up.
Old Apr 21, 2021 | 08:17 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
You have something else going on. Simply changing cap, rotor, & sparkplugs would not cause metal fragments in the oil. Improper ignition timing can cause a backfire...
Old Apr 21, 2021 | 08:38 PM
Ken56's Avatar
Axle/Gears: N/A
It's also a newer motor so I don't know if that would have anything to do with a little bit of metal fragments.
Old Apr 22, 2021 | 07:12 PM
HawkForum6's Avatar
Found ya Ken!
@aliceempire you where correct. We had a wire or two swapped. We pulled them all, found TDC on 1 and re-installed. Flushed the fuel tank, added new fuel and its running far better.
We also opened the oil filter up. There where some very small shavings in there, nothing substantial. Not knowing much at all about the motor, how long it was sitting, if it was started a bunch after sitting for a long time without priming etc we are not too concerned. We are going to move forward with it and see what it looks like after putting some miles on it.
86Lucille
Jul 19, 2019 02:22 AM
timboslice
Nov 22, 2014 09:04 AM
Zimmerser
Sep 20, 2011 08:31 PM
v8powr
Jul 12, 2002 11:14 PM
Nasty_Bird_'90
Feb 21, 2002 02:05 AM
