Clutch set-up?
Car: 92 Z28 Clone
Engine: Vortec 350
Axle/Gears: 3.23 Torsen
Clutch set-up?
Wondering if I have the right clutch for my set-up. First time setting one up so any help is appreciated. Would like some criticism on my setup and how shitty or "ok" its gonna drive.
Got a 350 vortec L31.
Decided to go with a pilot bushing instead of a bearing.
Using the Lt1 Stock flywheel.
Picked up this clutch kit . LUK-04134 Wondering if its correct for my application. Believe it is since lt1 is almost identical to l31.
Was in the midst of installing the pressure plate and realized I had the wrong bolts.(too short)
Now I'm waiting for some ARP-134-2202 which I believe are the correct bolts .
Using fourth gen pedals and hydraulics.
3.23 rear.
3.23 rear.
Re: Clutch set-up?
The only application for a LT1 clutch is when you're using a LT1 T-56. Won't work for anything else. Just like nothing else will work for that application.
L31 doesn't matter.
L31 doesn't matter.
