gta-89 engine idle /wont start when hot
Old May 20, 2021 | 11:50 AM
Tomas Wallin's Avatar
hello ...a pontiac transam gta -89 350tpi . car starts and runs okey until temparature goes up , then it start to goes up end down in rpm , if a turns off it wont starts untill it colds down ...any ide were to start searsing fault......
Old May 20, 2021 | 08:28 PM
Re: gta-89 engine idle /wont start when hot
Easiest kind of problem to fix IMO is a no-start. FAR easier than a runs-like-crap.
For an engine to run, all it needs is The Big 3 Ingredients: fuel/air, spark, compression.
Which one goes away?
I'm betting it's not compression; that doesn't go away when hot and return when cool.
That leaves air/fuel, and spark.
Does the throttle open? then it's not air. That leaves fuel and spark.
If it'll start with some starting fluid squirted into the throttle body, even if only for a second or 2, then it has spark, and it's a fuel problem, If that doesn't get it to start, then it's a spark problem.
Did I not say earlier that this is EEEEEEEEZZZZZZY?
My money would be on spark, if I was the betting kind. (I'm not) Specifically, the ignition module. But, don't just jump to that conclusion; do the troubleshooting.
TylerB46
May 2, 2020 09:38 AM
itsMikey
Aug 9, 2018 08:40 PM
penguinpanda0
Jun 25, 2013 06:57 AM
MikeDirntRulez
Nov 6, 2005 02:46 AM
