89 GTA wont start without giving it gas..iac?
Old Aug 3, 2018 | 11:51 AM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
so my car progressively went from running great to idling funny with sort of hard starts and now it wont start on its own at all...i turned the idle screw in a bunch and itll start and idle fine now (i know its only a bandaid)..is this a clear sign of a bad iac??
theres also a strange sort of tinging/grinding from the front of the engine..its VERY quiet though, idk if thats related at all, id guess not but figured id mention it anyway
thanks
Mikey
Old Aug 3, 2018 | 11:53 AM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
Re: 89 GTA wont start without giving it gas..iac?
Certainly sounds that way.
Old Aug 3, 2018 | 12:15 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
my thoughts exactly..guess ill order a new one and in the meantime, use my bandaid lol
edit..ordered new iac so we'll see soon
Old Aug 3, 2018 | 04:46 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
See if you can adjust the old one first, may just have moved.
Old Aug 3, 2018 | 07:17 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
it was tight when i took it out..was kind if dirty and a new one isnt too expensive
Old Aug 6, 2018 | 11:28 AM
KyleF's Avatar
Car: 1988 IROC-Z
Engine: 5.7 TPI
Axle/Gears: 3.45
Make sure you do the reset procedure. Get your timing and idle screw set right along with your TPS voltage.
Old Aug 9, 2018 | 08:40 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
i read the ecu resets it by itself after you cruise at 35mph for a while? ill return the idle screw where it was obviously but yeah
lkefthrlkeson
Feb 13, 2017 12:38 PM
scarr001
Jan 21, 2011 09:15 PM
Birdsong_'89_RS
May 6, 2008 10:01 PM
mrogers
Jun 24, 2007 06:38 PM
91Z28
Mar 8, 2002 03:05 PM
