Can bad cats ruin a tune up?
Old Aug 9, 2018 | 09:44 AM
rushtk's Avatar
Car: Teal 92 Z28
Engine: 5.7
Both cats went bad (the new stainless exhaust connected to the cats were cherry red) on the 92 Z28 5.7 we are restoring and now the motor is missing badly. The major tune up we had done has maybe 400 miles on it. We replaced injectors, wires, plugs, etc... Trying to get this thing finished so my son can drive it to school on the 28th of August.. His first car. Thanks for the input!
Old Aug 9, 2018 | 09:53 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Re: Can bad cats ruin a tune up?
No, they are post everything. The engine was the problem before the cats and is just worse after you noticed it
Old Aug 9, 2018 | 10:44 AM
GeneralDisorder's Avatar
If the exhaust was cherry red before the cat then it was either way too lean or the cats overheated because too rich/heavy misfiring.
GD
Old Aug 9, 2018 | 12:25 PM
Go Blue's Avatar
Clogged cats will cause the car to not accelerate well at all, but generally don't effect the tune up. The Oxygen sensors could mess up a tune if they aren't reading the oxygen count in the exhaust correctly and cause a rich or lean mixture.
Old Aug 9, 2018 | 02:07 PM
Wickydooda's Avatar
Old cats will clog up and restrict exhaust flow, causing the engine to run like crap or even (in my experience) cause the engine to die at higher rpm's.
I had clogged cats and when I downshifts and it got to over 3,000 rpms, the engine would die because it couldn't push the exhaust out fast enough.
Old Aug 10, 2018 | 09:10 AM
KyleF's Avatar
Car: 1988 IROC-Z
Engine: 5.7 TPI
Axle/Gears: 3.45
A clogged Cat on my 91 Mustang GT I had turned pipes red near the cats, but once it was switch had no other effect on the car. It ran like crap, had almost no power, and going to an off-road H-Pipe corrected it all. It was not a glowing bright read like a torch had seen hit it, but a very faint glow that I really only saw at night. That was how I determined it was a bad cat.
Old Aug 10, 2018 | 10:15 PM
rushtk's Avatar
Car: Teal 92 Z28
Engine: 5.7
Thank you for your help. The pipes were red from the cats back. The new stainless is now discolered. I was told to change plugs, rotar, and oil since this has happened.
Old Aug 11, 2018 | 06:32 AM
91RS5speed's Avatar
Car: 91 RS
Axle/Gears: Auburn Pro / 3.42
When you replaced the injectors what size did you put in?
Gordiggz
Jul 22, 2011 04:20 PM
customblackbird
Dec 9, 2007 03:42 PM
KiLLa MiKe
Oct 29, 2004 11:50 PM
SpeedCat86
Nov 4, 2001 06:27 PM
