Stalls When Warm While Starting Up?
Old Nov 5, 2005 | 01:45 AM
MikeDirntRulez's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI (L03)
Transmission: 700R4 (MD8)
Axle/Gears: 2.73 Open (GU2)
Hello,
I figured this should be put in the TBI section because you know how after you've been driving around a while, and you shut the car off and let it sit for about 30 minutes or so, you turn it back on and it makes the idle REALLY high and then lowers it to normal?
If you don't, my car does that. If its warm and you start it up again after it was shut off while warm, it shoots the RPMS up to about 2k, then down to about 500, where my normal warm idle is at.
Recently, when it does that, it will shoot way up, and as the RPMS are going down, it will shut off on me. No codes, no sputtering, it just turns off like you turned it off yourself with the key.
It's not annoying, because I will try and start it again and it will start right up with no problem. And it wont stall while i'm driving it, it just only stalls when I am attempting to start it up while warm.
Does anybody know what this could be? If you do, I would appreciate your feedback.
Thanks!
Old Nov 6, 2005 | 02:46 AM
Car: 1990 Camaro RS
nothing?
jklein337
Sep 19, 2018 06:23 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
Bryan F
Aug 18, 2015 02:28 PM
