89 Chevy Silverado Tech Question
Old Jan 16, 2002 | 10:47 PM
mcconahay37's Avatar
This question is about my Mom's truck. The steering column is loose at the tilt mechanism. It feels exactly the way my camaro did when I had that problem. Externally, the column looks the same as my camaro's. Is it the same internally, and can I fix it the same way? Are there any differences that might make this not doable?
Old Jan 16, 2002 | 11:00 PM
Vader's Avatar
Mac,
There should be no SIR, so it's essentially the same as your 'F' car column on the upper bowl end.
Remove the wheel, lock plate, turn signal switch, lock cylinder, linkages, bearings, and expose the universal joint in the tilt joint. Remove and clean the four Torx bolts, apply some LocTite 262, and torque them to 150-180 in/lb. Reassemble and drive off.
You probably have already seen this, but:
Old Jan 16, 2002 | 11:36 PM
Yeah. I have that pic saved on my harddrive Thanks for the confirmation. Knowing how much GM likes to use the same parts in multiple platforms, I figured it would be about the same. I'll get it fixed for her as soon as I get a chance. Thanks.
xkingcodex
Feb 12, 2020 07:43 PM
1Aauto
Sponsored Vendors
Apr 9, 2018 03:00 PM
Cleotiz
Jan 6, 2018 08:56 PM
NinjaNife
Aug 23, 2015 11:49 AM
redmaroz
Aug 16, 2015 11:40 PM
