Modifing fuel sender on 87 base to eliminate pump
Old Jun 17, 2021 | 08:59 AM
Ct1987's Avatar
Good morning all,
I installed the Holley sniper efi on my 305 about two years ago and it runs great. However when I installed the new sender with the eg\fi pump, I somehow mixed up the wires and my gas gauge does no work. I plan on dropping the tank and removing the in tank pump and install an in line pump and new fuel sensor. I need to install an extension to the fuel suction line and install a filter pickup. I did come across a photo of someone on this site that did just that and his mod was very neat. I searched and could not find his/her post again. When I eliminate the in tank pump i need an extension and filter.
Any help would be appreciated.
Louis
Old Jun 17, 2021 | 09:26 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: Modifing fuel sender on 87 base to eliminate pump
You can do something like this
https://www.thirdgen.org/forums/carb...nk-pickup.html
If you are running an external pump you might want to consider putting in a new pump in the tank while it is apart
Old Jun 17, 2021 | 03:56 PM
Ct1987's Avatar
Thanks, this is what I am looking for. He mentions that the line is brazed to the filter. Not sure how he did it without burning the filter.
How can I fasten the sock filter to the line and make sure it stays there.
Louis
IROCZ1989
Sep 5, 2019 09:13 AM
fadetoblack
Apr 15, 2016 08:44 PM
Maverick H1L
Apr 11, 2014 05:04 PM
seibertjd
Dec 9, 2011 07:10 PM
Joshua Leslie
Dec 27, 2001 07:24 PM
