AFR 195 identify numbers
Car: 1982 z/28 Right hand drive
Engine: 377 AFR195 750DP Solid cam 10.25:1
Transmission: TH/350 3200 stall spohn conversion
Axle/Gears: 10 bolt 3.42:1 Eaton Trutrac.
Got an engine with AFR heads i am looking at,,,,, apparently they are 195 intake Eliminator heads. AND still on the motor.
Front markings ar stamped L-98 SM
would these be the 65cc or 75cc chamber heads.
The heads are never run and still new and on a complete engine.
I want to know what the chamber size is so i can make an offer.
Car: 1985 Z28
Engine: 383
Axle/Gears: 10 bolt/3.73
Re: AFR 195 identify numbers
Transmission: T-5, TH350, T-5
Most of us are probably only going to be able to speculate. Might want to contact afr and ask. They have been pretty helpful to enthusiasts.
For the record, my 65cc chamber 180cc were L-98 SM. Probably denotes spark plug angle of L-98 and small chamber size. But again, I'm speculating.
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I bought a pre-eliminator set of AFR heads a few years back and IIRC when I called AFR with all the numbers on the heads they really weren't able to tell me anything about them expect the obvious. If you can't pull them to get measurements and volumes I would just be content knowing that they are an AFR head which for a SBC always ranks in the top of the list for head choices. But since those are Eliminator heads they may have better records.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Do you have pictures? Eliminator heads usually have barcode stickers on them.
-- Joe
-- Joe
Will look today
327_TPI_77_Maro
May 22, 2005 04:42 PM
