Aftermath of engine swap
Old Jan 17, 2002 | 04:16 PM
tpi_roc's Avatar
Hey guys
Just a quickie, I swapped out engines, all's well but now My heater controlls aren't working. I've got variable fan except the HIGHEST setting, and my "vent" was set to defrost during the swap and nothing will switch it off of it and to "vent" "heater" or otherwise.
What did I miss? It had to be in the engine bay, I dont have any vacuum lines left over except EGR which are plugged. The fan blower works..
Any ideas ?
Old Jan 17, 2002 | 04:24 PM
tpi_roc's Avatar
By the way the fuse is good
Old Jan 17, 2002 | 04:35 PM
Hellraiser's Avatar
The selector for the vents is vacuum operated... there should be at least two hoses coming through the firewall (near the drivers side?) that connect to manifold vacuum to operate it. Check those first.
Old Jan 17, 2002 | 04:38 PM
tpi_roc's Avatar
Are you reffering to the two vacuum lines that appear to head straight for both wiper motors?
What would explain my HIGH fan setting not working?
Old Jan 17, 2002 | 04:47 PM
tpi_roc's Avatar
Nevermind...
All fixed
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
