Can AFR 1040 heads work on a 1989 Camaro IROC-Z B2L engine?
My son has a 1989 Camaro IROC-Z with the engine code B2L and L98. I have a set of AFR 1040 (195 Street Eliminator 65cc heads). Can these heads be used on that B2L block? Also I have a set of CompCams 1418 1.6 ratio rockers. Should I use those or stick with the 1.5. the camshaft is the original one. Will there be any concerns with valve to piston clearance? Thanks
Car: 1989 IROC-Z
Engine: L98 350 TPI
Re: Can AFR 1040 heads work on a 1989 Camaro IROC-Z B2L engine?
Summit says the heads are based on L98 geometry so you're probably good there. 1.6 rockers should also be fine with a stock cam, but you should check during the mockup regardless.
If you're running TPI, it's possible that it will need tuning afterwards.
