I Was Debating...
Old Sep 21, 2021 | 04:11 PM
83 Crossfire TA's Avatar
I Was Debating...
If I was pulling the other cylinder head before reassembling the engine and finally decided I was having enough problems with the exhaust bolt holes stripping on the other one that I probably should pull it and Helicoil all of them on this one also and there has been enough weirdness with this engine that I probably should take a look...
Well, I guess it was a good thing:
I found 3 mud dauber nests inside the cylinders...
Old Sep 21, 2021 | 04:37 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Re: I Was Debating...
OK...that's a first for me.
Old Sep 22, 2021 | 12:22 AM
NoEmissions84TA's Avatar
Man, those little %*@$ers get in anywhere.
Old Sep 22, 2021 | 08:06 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Wow, that's crazy. I have the mud wasps that like to fill all the orifices in the engine(s). They did the fuel lines that were un capped, trans cooler lines, bolt holes.... such a PITA to clean out too
Old Sep 22, 2021 | 04:02 PM
I got the big chunks out with a shop vac, but I'm not sure what to do with the stuff stuck to the top of the pistons. I chipped the big stuff off but it comes off like concrete and I don't want that getting into the piston ring lands. The best idea I have so far is to find a brass brush to use in a Dremel and try to hold the vac nozzle next to it as I go but I've been to 3 hardware stores and I can't find any brass brushes (everyone has steel and stainless, neither of which do I really want to be using on a piston top inside an engine).
Old Sep 22, 2021 | 06:17 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Perhaps a chemical approach? Brake clean, purple power, simple green might dissolve it?
Old Sep 23, 2021 | 01:20 AM
Try Marvel Mystery Oil mixed with acetone.
Old Sep 23, 2021 | 01:59 AM
I actually already have that mixed up in the garage, it makes a decent lube for machining aluminum...
TaylorPeds
Dec 1, 2018 10:19 AM
PROPHET69
Jun 14, 2017 01:21 AM
BrianI
Sep 6, 2016 11:21 PM
84chvyz28
Aug 30, 2012 01:14 AM
Dingley
Aug 8, 2003 05:50 PM
